02 X-20 won't turn right
matty08
My 02 seadoo x-20 will not turn right at any speed above plain, but when docking, taking off, and putting around i have no problems. I can turn left at all speeds. Also while on plain to stay straight i need to keep the steering wheel cranked to the right. If anyone has experienced this or could let me know where to start looking. Avoiding a trip to the dealer saves money!
Thanks in advance
Stator.....
Look on the inside of your pumps nozzle. You will see a set of stationary vanes. These vanes counter the centrifugal force of the pumps thrust. If you have any bent or damage, this will cause your problem. You may be able to use a bright flashlight to do this inspection, looking from the rear of the nozzle.........Good luck. :cheers:
