R rogers66mm New Member Feb 15, 2009 #1 I'm taking the motor out and I'm down to the drive shaft and mounting brackets. Can you slide the motor ahead to separate it from the drive shaft or do you have to shuck the prop out of it to get the engine free.
nswillin Premium Member Premium Member Feb 15, 2009 #2 You can slide it forward and then remove the engine.
Chester Premium Member Premium Member Feb 15, 2009 #4 You'll have to pull the pump & driveshaft for the engine alignment tool when you reinstall the engine. Chester
