abethebabe
I purchased a 02 Explorer, with 3 aboard I have to back off the throttle while getting on plane as she is spinning. The wear ring clearance is fine, impeller looks good and with one aboard she jumps right up. Is this the nature of the boat? How can I check the seal for air leakage, will tipping it up on the trailer and letting some water cover the seal work (not much pressure at play). I am also thinking about a Swirl impeller and would appreciate some input on the best pitch for acceleration.
Mike
Mike
