Runaway engine...
There is many reasons for this but the most common is running lean. The next most common reason is sucking air, leaking past a gasket.
When your in the water, the pump will torque up and keep the engine from running away. But, you should be careful on land because an un-controlled runaway engine can melt plugs and pistons. Once the cyliner gets so hot, even killing the ignition will not shut it off. The best way is to use the choke......:cheers:
