Nbracing68
Ok Seadoo newbie here (but not new to Jetski’s). I have an 01 GTX Di that was given to me with issues. I replaced the original fuel pump (bad) with a Quantum pump and replaced the reg/rec because it wasn’t charging. The problem I’m having is a mild low rpm skip and a severe “bog” between approximately 3800-4200 rpm (have to really play with the throttle to keep it running). Once it clears 4200 it runs great. I’ve made it to 55 mph so far (water too rough to go faster so far). Wondering what the issue might be? It has new plugs, fresh 93 fuel and fresh oil. All filters have been changed (fuel & oil). Dash shows 270 hours but engine checks out at 127-125 psi compression. Any help would be greatly appreciated. Season is coming to an end quickly
