mark j
Recently did a air compressor test and disconnected the hose at the air rail. Reinstalled hose and noticed when I went to try to start that fuel is leaking from behind plate that secures air hose to rail. Help! Also, I need to replace lower end of air compressor due to low psi . Manual says that fly wheel must be removed in order to get to crank pin - I have been told that it does not any suggestions on both issues?
