Hi
I have an 01 challenger 1800 with the mercury 210 in it, it was starting funny like it would intermitantly just click and not turn over, so i would just cycle key and and then it would fire. It always fired but I decided I want to just change out the starter solenoid for maintenance.
I matched it up at west marine with a solenoid they had but i dont believe its the correct piece. The solenoid on boat has the two smaller posts with signal and ground and then the 2 larger posts for the starter circuit and its part# is 89-817109a1. The solenoid i picked up from west marine part# 89-817109a2 but the 2 smaller posts are signal and ign, which if i ran the ground to the ign terminal it would be a problem.
When i researched 89-817109a1 the solenoid would come up and advertise both part numbers as if they are the same part. So now im not sure if my existing one is even the correct solenoid, very confusing. Does anyone know more detail on this topic
Thanks
Thanks
