Paytention
Trying to fire up the boat on land for 1st time this season. Turned on the key and the engine cranked for about 2 secs. and stopped when I turned the key off. The ignition switch was loose so I fiddled with it and tightened it in the dash. Now, the engine will crank whether the switch is on or off and even if there is no key in the switch! It also cranks with the kill lanyard pulled off. I had to quickly switch the battery off in case the engine actually fired up with the starter motor still running. There do not appear to be any wires touching/shorting at the back of the ignition switch so I'm thinking the switch is bad. Does anyone have and ideas/opinions of the issue and where I can get a new switch (i.e. a generic one vs. OEM)? Thank you!
