Hull takes on water when it’s floating.
I replaced the carbon seal, wear ring and boot. No water coming through from there.
I have the ski hanging from a Davit over the water, looking for leaks. I found two around the penetrations for the OPAS linkage. I sealed those and they no longer leak.
I think I found the leak, but I don’t know how to go about sealing this up.
On the “carrier plate” (don’t know what it’s called, but it’s the plate that the pump attaches to via the 4- 1/2” studs)
Directly above the lower stud on both the left and right side there is a 3/16” - 1/4” hole in the plate. Nothing attaches to this, they are some type of outlet. The one on the left side has water from the hull dripping out, the right side has no water coming through. I can see light through each of these passages.
Anyone know what these passages are for and how they seal?
