Thanks for your help! I'm trying to crank by hand with the plugs removed. Also to clarify, it doesn't have a slow stop on either side like a compressing feel, but instead feels like a physical "clunk" when I'm trying to turn the PTO almost as if something is in the way. At first I thought that maybe I had a stuck rock in the impeller, but once I got home and removed the impeller that wasn't the case.
The issue that came up was when I was on the lake, my left engine started fine and my right engine (which used to work fine) wouldn't start. I tried starting it a few times and then it worked for about a minute and then stopped abruptly. I then docked the boat as I couldn't start the engine again after that since it wouldn't crank.
I got this boat last summer and the right engine (this one) had worked fine all season long until that day. The left engine gave me a lot of problems over the season, but those are all fixed now.
