If it has gray fuel lines then they need to be replaced, the carbs rebuilt with genuine mikuni kits following the sticky post at the beginning of this forum. Clean the fuel strainer. Change the jet pump oil and check the condition of the bearing, impeller and wear ring and pressure test it when done. Inspect the oil lines, especially the small ones the run to the carbs and replace if brittle. Adjust the oil pump and idle speed. All that should be done before using the ski if it sat a long time and you have no history of maintenance. There are other normal maintenance items listed in the shop manual.
