SeaDooDoo90
Trying to remove the carbs off a '95 XP and the four M8 socket cap screws will not budge. I've rounded out the two that are easier to access. Have tried a 1/4" hex bit, torx bit, triple square bit, shocking the screw head with some hammer pounds, applying a little heat, PB blaster from the underside. I've gotten both turned maybe a 1/2 turn and they will not budge any further.
I need to remove the entire assembly to have easier access. I see several sets of fasteners beneath the carbs attached to the intake manifold (I think Rotax calls it something different but it's an intake manifold to me). What's the simplest way to remove the entire assembly?
Once it's out, any tricks to remove the stuck socket cap screws? I don't think I've ever encountered bolts so badly seized
