No beep, no power...
flakko
Nothing happens when I connect dess lanyard... Been trouble shooting for about 4hrs... Battery at 12.7v, cleaned terminal, found blown rectifier fuse at solenoid, and 5a fuse at mpem. Replaced fuses, connect battery and immediately blow fuse at solenoid.. bench test mpem for bad diod=passed. Bench test dess post and key=passed. Unplug stator at rectifier harness, reconnect battery...no blown fuses, still no beep, no start... Advanced diagnostic no sound either.. bad rectifier? Bad Stator? Stator to ground in harness??? Frustrated and can't think what is next step to diagnose problem? Shouldn't dess work if Stator/rectifier faulty?
you said you disconnected the stator and no blown fuses. Preform resistance tests on the stator plug.
