I am working on a 1997 GTI. Removed everytning to clean inside hull and will be installing new engine. My question is about the thru hull fittings. THere are two under the rub rail on the starboard side of the ski. I know one is for the fuel system breather. But what is the other one for? There is a second opening for the fuel system also behind a cowl on the side of the dash, but I can't figure out the second hole under the rub rail. There was a 1.5 PSI check valve on it. I don't think it's for the oil system and I can't find any reference to it in the service manual. I've checked under the cooling system diagrams to see if it;s a pisser- but nothing there. the oil tank has a vent on a stubby hose inside the hull so I'm wondering if it's supposed to be for the oil tank.
Any thoughts? Anyone know for certain and / or own a 1997 GTI?
