I have a 2008 RXT 215 and a 2003 GTX 4-Tec SC. I have done most every inexpensive mod to increase speed/performance (no engine/supercharger mods) and it's given me a little more speed and rpm's. RXT hits 7950+/- RPM and about 72-73MPH on the stock speedo with a full tank of gas and two adults on board. GTX hits 63MPH and about 7300+/- RPM with a full tank of gas and two adults on board. The only thing I haven't done is replace my stock air intake. I have replaced both stock props with Solas, covered ride plate bolts with epoxy, blocked OPAS in the up position, put in new plugs, new Rotax oil/filter, free-flow exhaust (RXT only), and new wear rings. I'm not interested in a pump wedge or scoop grate because I ride in mainly flat/small chop water. My question is about the pros and cons of replacing the stock air intake with a custom (build it myself) 4" air intake with a K&N cone filter. Is it safe? What about water ingestion? With my current performance is it worth the risk to the engine to add the intake for maybe a 1MPH gain? If I do the mod, do I route the air filter so it sits just above the fuel tank (under the steering column)? What do I do about the smaller hoses that feed into/out-of the stock air intake near the battery? Do I completely remove the stock air box/breather that's up by the fuel tank? Can I expect significant gains in top speed/throttle response from this mod? This looks like a fairly easy and cheap mod to do. I'm looking for advice from those who have done it. Thanks!
By the way...the free-flow exhaust I added to the RXT made a HUGE difference in throttle response and it sounds awesome! I made my own exhaust pipe out of 2.5" automotive exhaust tubing bent at 90 degrees. I coated the inside and outside with galvanizing spray and then metal spray paint over that. I used adhesive style window caulk on the ends and three hose clamps on each end to secure the rubber exhaust tubing to the pipe. This ensures no water leaks and no chance of the pipe slipping out of the hose. I also made a rubber support brace to go between the metal pipe and the inside of the hull. This mod only cost me $20 and it made a big difference.
