Jlocutes
I have a 2007 rxp, i’ve noticed oil when I drain out the hull drain plugs. I also changed the oil and noticed that the oil filter was collapsed… Which I was told that usually water in the oil. I do not see any type of leaks the ski runs like a banshee never got an oil alarm etc. I recognized it when I was drai the hull started checking the oil levels.. i’m located in Roswell Georgia I don’t know if any members can recommend somebody to possibly pull the motor and change the gaskets etc. that’s what I was told I need to do on another form.. or if I find someone competent enough to do it and I can help them and I can learn a little bit about it I don’t have what I need to pull the motor however I probably could break it down and put it back together if I didn’t have to fool with the Pistons etc.
