Ilovehotdogz
Hi, I have a 2005 seadoo 3d w/ the 787rfi engine. Outside of the water the engine fires up, within 2 tries, revs up and sounds good. I can post a video if it will help find issue. I dropped the ski in the lake today, took 3 tries to fire up, yes I started it before I put it in. It wouldn't idle in the water so I held throttle 1/4 to keep it going, it did about 4mph, when i pulled throttle all the way down it would not rev up, maybe jumped to 7mph and almost sounded like it was going to die so I left off and kept it 1/4 and kept trying to do more, in 10min it never shut down on me but wouldn't go any faster, it was like this the whole time.
It has new plugs, fresh gas, and new fully charged battery. After I took it out of the water, I fired it up took 3 tries and it struggled to start, the more water it pumped out of it the better and better it started sounding and then it started to rev up again and sounds pretty good, wth? I've read a lot of posts on here and have ideas but not sure and hoping to get others input?
could it be a small clog in the cooling system? where do I start to look for that, from the outside the hoses, elbows, t fittings look good, they don't look shrunk, melted or otherwise not right.
I took all the exhaust out, did a short pipe mod. The 3 water adapters on the bottom of main exhaust housing looked good or at least clean, easy to blow through them. last year replaced the regulator as when I checked seemed to have low voltage, the new one is great and reads right, so I don't think its that.
any help or ideas of where I can continue to fix this problem. in this post someone talks about the rave valves and causing there 04 to bog down, they say the rave valves should be screwed in all the way or at least flush with the black tops. I've cleaned my valves, they look very clean, no carbon but the red piece is screwed about a 1/5 inch past the top of the black nozzle, could this be the problem? super easy fix if it is, just unscrew them, if so why does it work outside of the water but not in the water, is it due to back pressure in the exhaust then? http://www.seadooforum.com/showthread.php?8296-Sea-doo-3d-lack-of-power-(Bogging)-problem
I can post pictures/ videos of anything you guys think will help you help me diagnose and fix this problem. Thanks in advance for any help!
there is a black sludge in the back of the ski? like a mixture of water, oil and exhaust? can be scene in pics -
