dingo555
Took our speedster out for a lap today and had the check engine light coming on and if I tried to go over 6000rpm it would go into limp mode and would then not go over 2000rpm. Boat has not been in the water since April and it was running perfect at that point. Engine bay is always dry and spotless and engine was sprayed with WD-40 after cleaning and going in the shed. Boat spends 90% of its life in the fresh water has 56hrs on it and is well maintained. I siphoned most of the old fuel out and filled it with fresh premium (before it even went in the water). i have been through every electrical connector I can find to check for signs of corrosion etc. Any ideas from anyone before I have to drive 300kms to my nearest dealer would be appreciated. Cheers.
